Toshiba Satellite A75-S226 CD Drive Replacement
  1. Toshiba Satellite A75-S226 CD Drive Replacement, Optical Drive: step 1, image 1 of 2 Toshiba Satellite A75-S226 CD Drive Replacement, Optical Drive: step 1, image 2 of 2
    • Remove the two 5.62 mm screws from the optical drive cover.
  2. Toshiba Satellite A75-S226 CD Drive Replacement: step 2, image 1 of 2 Toshiba Satellite A75-S226 CD Drive Replacement: step 2, image 2 of 2
    • Remove the optical drive cover.
    • A plastic opening tool or a fingernail may be helpful in lifting it from its groove.
  3. Toshiba Satellite A75-S226 CD Drive Replacement: step 3, image 1 of 1
    • Using the inset divot, push the optical drive out of the laptop to remove.
  4. Toshiba Satellite A75-S226 CD Drive Replacement, CD Drive: step 4, image 1 of 3 Toshiba Satellite A75-S226 CD Drive Replacement, CD Drive: step 4, image 2 of 3 Toshiba Satellite A75-S226 CD Drive Replacement, CD Drive: step 4, image 3 of 3
    • Remove the 8.6 mm screw.
  5. Toshiba Satellite A75-S226 CD Drive Replacement: step 5, image 1 of 3 Toshiba Satellite A75-S226 CD Drive Replacement: step 5, image 2 of 3 Toshiba Satellite A75-S226 CD Drive Replacement: step 5, image 3 of 3
    • Push the bottom left corner of the CD Drive until the drive protrudes from the case.
    • When a good amount of the CD Drive is showing on the right side, gently pull it out completely.
Garrett Gudgel
763 Reputation
13 Guides authored
Cal Poly, Team 4-43, Amido Fall 2010 Member of Cal Poly, Team 4-43, Amido Fall 2010
CPSU-AMIDO-F10S4G43
5 Members
39 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 3,434
