Introduction
Installing the RAM is a quick and easy process, just make sure you have the appropriate RAM for your laptop. The Toshiba Satellite A215 S4697 has a max of 4GB of RAM. This means two 2GB of RAM cards.
Close the laptop and turn it over so that the base is facing upwards and the spine is away from you.
Unscrew the two captive screws with the Phillips #1 and open the compartment.
6 other people completed this guide.
One Comment
ned solution for my satitillate pro as the fix i need is not listed . my Toshiba is a l875d-s7332 and cu
ls not find the right as the fix given is for and older moldel, can i pls get the right data mailed to my email asasp pls
