Introduction
Some times the computers trackpad can become unreliable or unresponsive. It is possible to remove the track pad to clean the connections. and reinstall.
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Disconnect wire attaching LCD to motherboard
Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
Using the pry tool separate the two halves of the laptop base.
Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
Remove the 3 4.5mm screws holding the track-pad in place.
There are some screws that will be hidden by assembly tape.
