This teardown is in progress – Reload periodically to see the latest changes!
  1. Disassembling Toshiba Satellite A105-S4284 laptop main body, Keyboard: step 1, image 1 of 1
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  2. Disassembling Toshiba Satellite A105-S4284 laptop main body: step 2, image 1 of 3 Disassembling Toshiba Satellite A105-S4284 laptop main body: step 2, image 2 of 3 Disassembling Toshiba Satellite A105-S4284 laptop main body: step 2, image 3 of 3
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  3. Disassembling Toshiba Satellite A105-S4284 laptop main body: step 3, image 1 of 2 Disassembling Toshiba Satellite A105-S4284 laptop main body: step 3, image 2 of 2
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  4. Disassembling Toshiba Satellite A105-S4284 laptop main body: step 4, image 1 of 3 Disassembling Toshiba Satellite A105-S4284 laptop main body: step 4, image 2 of 3 Disassembling Toshiba Satellite A105-S4284 laptop main body: step 4, image 3 of 3
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
  5. Disassembling Toshiba Satellite A105-S4284 laptop main body, Disassembling Toshiba Satellite A105-S4284 laptop main body: step 5, image 1 of 3 Disassembling Toshiba Satellite A105-S4284 laptop main body, Disassembling Toshiba Satellite A105-S4284 laptop main body: step 5, image 2 of 3 Disassembling Toshiba Satellite A105-S4284 laptop main body, Disassembling Toshiba Satellite A105-S4284 laptop main body: step 5, image 3 of 3
    • Disconnect wire attaching LCD to motherboard
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
  6. Disassembling Toshiba Satellite A105-S4284 laptop main body: step 6, image 1 of 2 Disassembling Toshiba Satellite A105-S4284 laptop main body: step 6, image 2 of 2
    • Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
    • Using the pry tool separate the two halves of the laptop base.
    • Use caution when separating the laptop halves as they are still connected by two ribbon cables.
  7. Disassembling Toshiba Satellite A105-S4284 laptop main body: step 7, image 1 of 2 Disassembling Toshiba Satellite A105-S4284 laptop main body: step 7, image 2 of 2
    • Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
Josh
685 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 16
All Time: 907
