Introduction
Use this guide to replace the keyboard on your Toshiba Satellite.
Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
Fully detach the strip.
Carefully pull upwards on the ribbon cable to detach.
Remove keyboard.
Do not pull any ribbon cable. Instead slide moving part upwards. The ribbon is now loose and can be removed without the slightest force. The keyboard connection is similar.
Almost done!
