Toshiba SD-K740 Motherboard Fuse Replacement
  1. Toshiba SD-K740 Motherboard Fuse Replacement, Top Panel: step 1, image 1 of 1
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Motherboard Fuse Replacement: step 2, image 1 of 2 Toshiba SD-K740 Motherboard Fuse Replacement: step 2, image 2 of 2
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Motherboard Fuse Replacement: step 3, image 1 of 1
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Motherboard Fuse Replacement, Motherboard Fuse: step 4, image 1 of 2 Toshiba SD-K740 Motherboard Fuse Replacement, Motherboard Fuse: step 4, image 2 of 2
    • Using the plastic opening tool, gently pop the fuse out of its restraining brackets.
John Lokker
324 Reputation
3 Guides authored
Cal Poly, Team 1-16, Amido Winter 2011 Member of Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 3,856
