Toshiba Portege M300 RAM Replacement
  1. Toshiba Portege M300 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 RAM Replacement: step 2, image 1 of 2 Toshiba Portege M300 RAM Replacement: step 2, image 2 of 2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 RAM Replacement: step 3, image 1 of 2 Toshiba Portege M300 RAM Replacement: step 3, image 2 of 2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 RAM Replacement, RAM: step 4, image 1 of 3 Toshiba Portege M300 RAM Replacement, RAM: step 4, image 2 of 3 Toshiba Portege M300 RAM Replacement, RAM: step 4, image 3 of 3
    • Turn the computer over onto the back.
    • Use a Phillips head screwdriver to remove the screw holding the RAM cover in place, and lift the cover.
    • One 4.0 mm coarse thread screw.
  5. Toshiba Portege M300 RAM Replacement: step 5, image 1 of 3 Toshiba Portege M300 RAM Replacement: step 5, image 2 of 3 Toshiba Portege M300 RAM Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to open the silver flaps on either side of the RAM.
    • Once both flaps are released, the RAM should pop up at an angle.
  6. Toshiba Portege M300 RAM Replacement: step 6, image 1 of 2 Toshiba Portege M300 RAM Replacement: step 6, image 2 of 2
    • Grasp both sides of the RAM and pull to remove it.
Alison Wendt
135 Reputation
6 Guides authored
Cal Poly, Team 21-51, Johann Spring 2013 Member of Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
3 Members
18 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 14
All Time: 1,244
