Introduction
This guide goes through the steps needed to install a new keyboard. Attention to detail is required in order to reverse the steps for instillation of a new key bored, returning each screw to the correct location.
Slide the lock on the left side to the unlock position.
Slide the lock on the right side to the unlock position until there is a clicking sound.
Use a Phillips head #00 screwdriver to remove the two silver screws at the top of the keyboard.
Turn the computer over on to the back.
Remove the middle screw with a Phillips head #000 screwdriver.
Turn the computer over to the front.
Gently pull at the top and bottom to remove the keyboard.
Peel off the black tape that holds the connection wire.
