(Archived) Toshiba L755 Hard Drive Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. (Archived) Toshiba L755 Hard Drive Replacement, Remove the battery: step 1, image 1 of 3 (Archived) Toshiba L755 Hard Drive Replacement, Remove the battery: step 1, image 2 of 3 (Archived) Toshiba L755 Hard Drive Replacement, Remove the battery: step 1, image 3 of 3
    • Remove the battery from the laptop. To do this, by unlocking the battery from the computer, and then hold the spring release clip back, while pulling the battery out of the laptop.
    • Optional: Once you remove the battery, hold the power button down for 10-15 seconds to drain the system. This is optional, so you don't have to do this if you choose not to.
  2. (Archived) Toshiba L755 Hard Drive Replacement, Remove the hard drive door: step 2, image 1 of 2 (Archived) Toshiba L755 Hard Drive Replacement, Remove the hard drive door: step 2, image 2 of 2
    • Remove the 2 screws from the hard drive door. Lift the door up with a plastic pry tool.
    • If you have one available, you can use a spudger as well. However, plastic pry tools will suffice.
  3. (Archived) Toshiba L755 Hard Drive Replacement, Remove the drive clip screw: step 3, image 1 of 3 (Archived) Toshiba L755 Hard Drive Replacement, Remove the drive clip screw: step 3, image 2 of 3 (Archived) Toshiba L755 Hard Drive Replacement, Remove the drive clip screw: step 3, image 3 of 3
    • Remove the screw holding the hard drive in the computer. Slide the drive backwards to remove it from the laptop.
  4. (Archived) Toshiba L755 Hard Drive Replacement, Remove the drive clip: step 4, image 1 of 2 (Archived) Toshiba L755 Hard Drive Replacement, Remove the drive clip: step 4, image 2 of 2
    • Remove the hard drive mounting bracket. Loosen the 2 highlighted screws to remove it from the bracket.
  5. (Archived) Toshiba L755 Hard Drive Replacement, Replace the drive bracket: step 5, image 1 of 3 (Archived) Toshiba L755 Hard Drive Replacement, Replace the drive bracket: step 5, image 2 of 3 (Archived) Toshiba L755 Hard Drive Replacement, Replace the drive bracket: step 5, image 3 of 3
    • Screw the hard drive bracket on the new hard drive.
  6. (Archived) Toshiba L755 Hard Drive Replacement, Replacing the drive in the laptop: step 6, image 1 of 3 (Archived) Toshiba L755 Hard Drive Replacement, Replacing the drive in the laptop: step 6, image 2 of 3 (Archived) Toshiba L755 Hard Drive Replacement, Replacing the drive in the laptop: step 6, image 3 of 3
    • Reinstall the hard drive in the laptop. Put the drive in the system as shown. Push the drive forward to lock the drive in. Once you do this, screw the drive in the laptop.
    • If you are using an SSD, you will need a 7mm to 9.5mm adapter. A lot of SSD's include this, but you may have to buy one. You can stick this in the chassis of the laptop or on the drive. Note: All modern SSD's are 7mm. Hard drives are either 7mm or 9.5mm. If you are dealing with a spinning drive, a 7mm-9.5mm adapter may not be an option.
  7. (Archived) Toshiba L755 Hard Drive Replacement, Screw the hard drive cover back on: step 7, image 1 of 2 (Archived) Toshiba L755 Hard Drive Replacement, Screw the hard drive cover back on: step 7, image 2 of 2
    • Screw the hard drive cover on the laptop. Once it is screwed in, snap it down to secure it.
  8. (Archived) Toshiba L755 Hard Drive Replacement, OS installation: step 8, image 1 of 1
    • Once the hard drive is replaced, install the operating system on the laptop.
    • For Windows: you will need a Microsoft or Digital River ISO, if you are getting it online. If you do not have an image on hand, it is generally considered safer to buy an OEM DVD without a product key. Unless you can find other official means to get the ISO, I do not recommend using an ISO from the Internet.
    • Non Microsoft OSes: The problem with this is I do not know what you want to install. If I know how to find it I may be able to help you, but I cannot guarantee that I know for sure and can help you find the ISO you need. As such, you are probably on your own.
Nick
88,933 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,545 Guides authored
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 43
All Time: 8,960
