Toshiba Excite 7c Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
90
All Time:
501
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 6 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will show you how to replace the camera on your Toshiba Excite 7c. The camera itself plugs directly into the motherboard and can be slightly more difficult to replace than other componants.
Tools
    1. Toshiba Excite 7c Camera  Replacement, Motherboard: step 1, image 1 of 2 Toshiba Excite 7c Camera  Replacement, Motherboard: step 1, image 2 of 2
      • Place an iFixit opening tool in the seam between the screen and back casing.
      • Apply pressure down all four sides to separate the back casing from the screen.
      • Place the tablet face down and carefully remove the back panel.
      Ask FixBot
    2. Toshiba Excite 7c Camera  Replacement: step 2, image 1 of 2 Toshiba Excite 7c Camera  Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Use a Phillips screwdriver to remove the five 6 mm screws from the motherboard.
      • Use tweezers to gently disconnect the two ribbon cables.
      • Pull straight up to remove the board.
      Ask FixBot
    1. Toshiba Excite 7c Camera  Replacement, Camera: step 3, image 1 of 3 Toshiba Excite 7c Camera  Replacement, Camera: step 3, image 2 of 3 Toshiba Excite 7c Camera  Replacement, Camera: step 3, image 3 of 3
      Buy
      • Locate the camera on the top portion of the motherboard as seen here.
      • Grip using the tweezers and pull directly up applying as much force as necessary to remove the camera.
      Ask FixBot
Reyna Serrato
96 Reputation
5 Guides authored
Gateway, Team 1-2, Johnson Fall 2014 Member of Gateway, Team 1-2, Johnson Fall 2014
GCC-JOHNSON-F14S1G2
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 90
All Time: 501
