Toshiba Chromebook 2 Back Cover Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Toshiba Chromebook 2 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Back Cover Replacement: step 2, image 1 of 1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Back Cover Replacement: step 3, image 1 of 2 Toshiba Chromebook 2 Back Cover Replacement: step 3, image 2 of 2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Back Cover Replacement: step 4, image 1 of 2 Toshiba Chromebook 2 Back Cover Replacement: step 4, image 2 of 2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Back Cover Replacement: step 5, image 1 of 1
    • Remove the back panel by pulling up on 2 adjacent corners.
Haley Hattendorf
598 Reputation
2 Guides authored
Cal Poly, Team 10-4, Livingston Fall 2016 Member of Cal Poly, Team 10-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G4
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 92
