Toshiba CB35-CB3300 Chromebook 2 Fan replacement
  1. Toshiba CB35-CB3300 Chromebook 2 Fan replacement, Back Cover: step 1, image 1 of 2 Toshiba CB35-CB3300 Chromebook 2 Fan replacement, Back Cover: step 1, image 2 of 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 2, image 1 of 2 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 2, image 2 of 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 3, image 1 of 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 4, image 1 of 2 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 4, image 2 of 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-CB3300 Chromebook 2 Fan replacement, Battery: step 5, image 1 of 2 Toshiba CB35-CB3300 Chromebook 2 Fan replacement, Battery: step 5, image 2 of 2
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 6, image 1 of 2 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 6, image 2 of 2
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 7, image 1 of 3 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 7, image 2 of 3 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 7, image 3 of 3
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 8, image 1 of 2 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 8, image 2 of 2
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Toshiba CB35-CB3300 Chromebook 2 Fan replacement, Fan: step 9, image 1 of 1
    • Locate the fan
  10. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 10, image 1 of 1
    • Unscrew the 4 Phillip screws using a Phillips # 1 Screwdriver.
    • These screws only loosen partially, they do not disconnect.
  11. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 11, image 1 of 3 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 11, image 2 of 3 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 11, image 3 of 3
    • The top wire is the fan's wire. Remove it by pulling it from the motherboard.
  12. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 12, image 1 of 3 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 12, image 2 of 3 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 12, image 3 of 3
    • To remove the Wifi PCB wire lift up the hinged flap with your finger or with the aid of the spudger tool.
    • After the flap is lifted, pull the wire up out of the connector socket.
  13. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 13, image 1 of 2 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 13, image 2 of 2
    • Remove the headphone jack wire by pulling it out of the connector socket.
  14. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 14, image 1 of 1
    • Remove the Phillip 3.6 mm screw from the fan using a Phillips #1 screwdriver.
  15. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 15, image 1 of 1
    • Lift up on the metal plate that hold the screws to start removing the fan.
  16. Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 16, image 1 of 3 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 16, image 2 of 3 Toshiba CB35-CB3300 Chromebook 2 Fan replacement: step 16, image 3 of 3
    • Once lifted, you will notice that there are two wires tucked under plastic tunnels on the right side of the fan. Remove these wires.
    • These wires require you to gently pull them out of there tunnel.
    • Once the wires are removed the fan should be removed entirely.
varun kapadia
219 Reputation
1 Guide authored
USF Tampa, Team S1-G121, Cagle Fall 2017 Member of USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 Members
14 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 10
All Time: 979
