TopTro TR25 Dust Filter Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
55
All Time:
536
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you are looking to replace or just clean the dust filter, this guide is for that. You'll need an opening tool such as a plastic or metal spudger. The steps are straightforward and don't involve anything overtly complicated, but be sure to be careful to avoid damage to the rivets.
Tools
  • Spudger
    4.9
  • Spudger
    $3.99
    4.9
    1. TopTro TR25 Dust Filter Replacement, Dust filter: step 1, image 1 of 1
      • Place the projector face down so rear is facing up.
      Ask FixBot
    2. TopTro TR25 Dust Filter Replacement: step 2, image 1 of 2 TopTro TR25 Dust Filter Replacement: step 2, image 2 of 2
      • Wedge a spudger into the half-circle idnent and pry the panel off until it partially pops open.
      • Go around the perimeter of the panel with the spudger to pry it the rest of the way off.
      • Be careful not to apply too much force so that the pop tabs holding it on don't break.
      Ask FixBot
    3. TopTro TR25 Dust Filter Replacement: step 3, image 1 of 2 TopTro TR25 Dust Filter Replacement: step 3, image 2 of 2
      • The panel you've just removed has a foam dust filter in it. It is not attached to the panel, so just remove it by hand.
      • If possible, clean the original dust filter and put it back onto the panel.
      Ask FixBot
    4. TopTro TR25 Dust Filter Replacement: step 4, image 1 of 2 TopTro TR25 Dust Filter Replacement: step 4, image 2 of 2
      • Reattach the panel to the projector. The side opposite the indent you used to open it has tabs and that side needs to go in first.
      • Apply pressure all around the edge until the panel is fully attached.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 55
All Time: 536
