TomTom XL Battery Replacement
  1. TomTom XL Battery Replacement, Screen and Motherboard: step 1, image 1 of 1
    • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
    • Starting at the corners, carefully pry up the screen bezel.
  2. TomTom XL Battery Replacement: step 2, image 1 of 1
    • Remove the four Phillips #00 screws around the edge of the screen.
  3. TomTom XL Battery Replacement: step 3, image 1 of 3 TomTom XL Battery Replacement: step 3, image 2 of 3 TomTom XL Battery Replacement: step 3, image 3 of 3
    • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
    • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
    • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
    • Remove the frame from the housing.
  4. TomTom XL Battery Replacement: step 4, image 1 of 2 TomTom XL Battery Replacement: step 4, image 2 of 2
    • Lifting from the upper edge of the screen, tilt the screen away from the device.
    • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
  5. TomTom XL Battery Replacement: step 5, image 1 of 2 TomTom XL Battery Replacement: step 5, image 2 of 2
    • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
    • Two Phillips #00 screws are located at the bottom of the first picture.
    • The third screw is hidden under the orange ribbon cable, near the screen.
    • You may have to carefully lift the screen in order to reach this screw.
  6. TomTom XL Battery Replacement: step 6, image 1 of 2 TomTom XL Battery Replacement: step 6, image 2 of 2
    • Flip the screen and motherboard over.
    • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
    • Disconnect the speaker cable connector from the motherboard.
    • Remove the motherboard and screen from the housing.
  7. TomTom XL Battery Replacement, Battery: step 7, image 1 of 1
    • Slip a small plastic opening tool under the battery and slowly pry the battery up.
    • The battery is held on with strong adhesive, so it may require some force. Work slowly and carefully to avoid damaging the housing
    • Remove the battery from the housing.
Sean Higginson
209 Reputation
2 Guides authored
Cal Poly, Team 33-84, Johann Spring 2010 Member of Cal Poly, Team 33-84, Johann Spring 2010
CPSU-JOHANN-S10S33G84
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 51
All Time: 51,476
