Introduction
Guide to replace the battery in the Tom Tom XL.
Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
Starting at the corners, carefully pry up the screen bezel.
Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
Remove the frame from the housing.
Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
Two Phillips #00 screws are located at the bottom of the first picture.
The third screw is hidden under the orange ribbon cable, near the screen.
Flip the screen and motherboard over.
Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
Disconnect the speaker cable connector from the motherboard.
Remove the motherboard and screen from the housing.
Once the screen and motherboard are completely removed from the housing, the battery is now accessible
Slip a small iPod opening tool or flat head screwdriver under the battery and slowly pry it out
It is held on with strong adhesive, so it may require some force but be careful as to not damage the housing
Once removed, slip in the new battery
