TomTom Go Blue and Me Disassembly
    1. TomTom Go Blue and Me Disassembly, Remove the bezels: step 1, image 1 of 2 TomTom Go Blue and Me Disassembly, Remove the bezels: step 1, image 2 of 2
      • Use a flat head screwdriver or plastic spatula to remove the bezels from the side of the screen.
      • Now the torx screws are visible
      Ask FixBot
    2. TomTom Go Blue and Me Disassembly, Disconnect screen from mainboard: step 2, image 1 of 2 TomTom Go Blue and Me Disassembly, Disconnect screen from mainboard: step 2, image 2 of 2
      • When the screws are out, the screen is separated from the back of the housing.
      • the screen is still connected with a flat cable and a power cable
      • The power cable should be pulled first
      • The flat cable can be disconnected by lifting up the black part of the connector.
      Ask FixBot
    3. TomTom Go Blue and Me Disassembly, Disconnect battery and loudspeaker: step 3, image 1 of 2 TomTom Go Blue and Me Disassembly, Disconnect battery and loudspeaker: step 3, image 2 of 2
      • Next, the main board should be disconnected from the battery
      • and from the loud speaker
      Ask FixBot
    4. TomTom Go Blue and Me Disassembly, Battery and loudspeaker: step 4, image 1 of 2 TomTom Go Blue and Me Disassembly, Battery and loudspeaker: step 4, image 2 of 2
      • You can now unscrew the mainboard
      Ask FixBot
    5. TomTom Go Blue and Me Disassembly, access to battery and loudspeaker: step 5, image 1 of 1
      • When you now lift out the mainboard, you have access to the battery and loudspeaker.
      • The battery is glued in. you need to heat it up to get it out.
      Ask FixBot
    6. TomTom Go Blue and Me Disassembly, On/Off button: step 6, image 1 of 2 TomTom Go Blue and Me Disassembly, On/Off button: step 6, image 2 of 2
      • This little piece of plastic was my reason for opening it up. The longer leg was broken. I glued it with superglue and put it back. so far this seams feasible
      • Please note the broken bits in the holes at the end of the legs: you can not actually take this out without breaking it! so be ware!
      Ask FixBot
hjheins
277 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 1,660
