Tolino Vision Battery Replacement
Views: 23K
View statistics:
Past 24 Hours:
18
Past 7 Days:
138
Past 30 Days:
548
All Time:
23,443
Comments: 11
6 comments on steps, 5 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Here is the corrected text:
My Tolino E-Book Reader's battery was so discharged after about a year of non-use that it had to be replaced with a new one.
A type PR-285083 battery (3.7V /1500mAh) is needed. The price is about 14€.
    1. Tolino Vision Battery Replacement, Battery: step 1, image 1 of 1
      • First, open the edge of the Tolino with a spudger or pick. The lid is only clipped and can be opened easily.
      Ask FixBot
    2. Tolino Vision Battery Replacement: step 2, image 1 of 3 Tolino Vision Battery Replacement: step 2, image 2 of 3 Tolino Vision Battery Replacement: step 2, image 3 of 3
      • Update: The cable (and the ribbon cables) are secured with a bit of silicone. This can be removed quite easily, like a sticker.
      • Now disconnect the battery cable. Carefully pry it off from underneath.
      Ask FixBot
    3. Tolino Vision Battery Replacement: step 3, image 1 of 1
      • The battery is secured in the middle with fairly strong tape. Carefully slide a spudger underneath and loosen it.
      Ask FixBot
      • Glue in the new battery and connect it.
      Ask FixBot
      • Clip the housing back on and switch on the Tolino.
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
7 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Micha
281 Reputation
1 Guide authored
5 Guide Comments
sehr einfach. danke
Walter Bruder - Reply Share
Sehr gut, danke!
Christof Waas - Reply Share
Bei meinem Tolino war der Bildschirmrahmen innen mit einem Kunststoffrahmen verklebt, der unten an der Platine angenietet ist. Dadurch konnte der Bildschirmrahmen nicht ohne weiteres vom Gehäuseboden getrennt werden. Die Verklebung war ziemlich hartnäckig. Leider ist beim Lösen der Verklebung der Bildschirmrahmen an verschiedenen Stellen gebrochen. Zudem war die Platine mit 4 Schrauben am Gehäuseboden festgeschraubt. Erst danach bin ich an den Akku gekommen.
War nicht ganz so problemlos wie beschrieben, aber ohne diesen Input wäre ich gar nicht auf die Idee gekommen, den Tolino zu öffnen (lag schon im Elektroschrott....). Jetzt bekommt er ein zweites Leben ;-)
Thomas G - Reply Share
Danke für den Tipp. Beim Vision 8 ist der Akku leider verlötet. Mal sehen ob das klappt.
niyou - Reply Share
@niyou Und hat es geklappt?
Martin Ortlieb - Reply Share
Past 24 Hours: 18
Past 7 Days: 138
Past 30 Days: 548
All Time: 23,443
