Timer Switch Relay Replacement
  1. Timer Switch Relay Replacement, Relay: step 1, image 1 of 2 Timer Switch Relay Replacement, Relay: step 1, image 2 of 2
    • Locate the screw holes.
  2. Timer Switch Relay Replacement: step 2, image 1 of 2 Timer Switch Relay Replacement: step 2, image 2 of 2
    • Use the #1 Phillips head screwdriver to remove the screws. This may cost some prying effort.
  3. Timer Switch Relay Replacement: step 3, image 1 of 2 Timer Switch Relay Replacement: step 3, image 2 of 2
    • Open the case by pulling the back case from the front case.
  4. Timer Switch Relay Replacement: step 4, image 1 of 3 Timer Switch Relay Replacement: step 4, image 2 of 3 Timer Switch Relay Replacement: step 4, image 3 of 3
    • Use the #1 Phillips head screwdriver to remove the screws on the inside.
  5. Timer Switch Relay Replacement: step 5, image 1 of 3 Timer Switch Relay Replacement: step 5, image 2 of 3 Timer Switch Relay Replacement: step 5, image 3 of 3
    • Pull the PCB (printed circuit board) from the case.
  6. Timer Switch Relay Replacement: step 6, image 1 of 3 Timer Switch Relay Replacement: step 6, image 2 of 3 Timer Switch Relay Replacement: step 6, image 3 of 3
    • Locate the relay.
    • Locate where the relay is connected to the PCB.
  7. Timer Switch Relay Replacement: step 7, image 1 of 3 Timer Switch Relay Replacement: step 7, image 2 of 3 Timer Switch Relay Replacement: step 7, image 3 of 3
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Melt the solder with the soldering iron.
    • Don't burn yourself by touching the hot soldering iron tip.
    • Use the desoldering pump to suck up the old solder.
    • Pull the relay from the PCB.
  8. Timer Switch Relay Replacement: step 8, image 1 of 2 Timer Switch Relay Replacement: step 8, image 2 of 2
    • Put a new relay at the same place as the old relay.
    • Use new solder and the soldering iron to connect the new relay to the PCB.
One Comment
Very nice instruction, also for maintaining gardening equipment as a robotic lawnmower.
theodevries - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 774
