Timemore Black Mirror Mini Slide Switch Replacement
    1. Timemore Black Mirror Mini Slide Switch Replacement, Open the Black Mirror Mini: step 1, image 1 of 3 Timemore Black Mirror Mini Slide Switch Replacement, Open the Black Mirror Mini: step 1, image 2 of 3 Timemore Black Mirror Mini Slide Switch Replacement, Open the Black Mirror Mini: step 1, image 3 of 3
      Tool used on this step:
      Jimmy
      $7.95
      Buy
      • Using a Jimmy, peel back the label on the bottom plate.
      • Using a Phillips #1 Screwdriver, remove the two black screws in the middle of the bottom plate. These screws might be quite tight.
      • Using an Opening Pick, separate the top plate from the bottom plate.
      Ask FixBot
    2. Timemore Black Mirror Mini Slide Switch Replacement, Solder switch bypass: step 2, image 1 of 2 Timemore Black Mirror Mini Slide Switch Replacement, Solder switch bypass: step 2, image 2 of 2
      Buy
      • Set the slide switch to the ON (right) position.
      • Using your Soldering Skills and Tweezers, solder a jumper wire between the bottom two poles of the slide switch to bypass it.
      • If you don't have a soldering iron, you could try gluing aluminum foil across the two poles to electrically join them.
      Ask FixBot
    3. Timemore Black Mirror Mini Slide Switch Replacement, Close the Black Mirror Mini: step 3, image 1 of 2 Timemore Black Mirror Mini Slide Switch Replacement, Close the Black Mirror Mini: step 3, image 2 of 2
      $5.49
      Buy
      • Place the top plate back on the bottom plate.
      • Using a Phillips #1 Screwdriver, screw the two black screws back into the middle of the bottom plate.
      • Reapply the label to the bottom plate and press firmly to secure it.
      Ask FixBot
You can now use the soft key on the top plate to power the unit on or off:
  • To turn the unit on, press the power button on the top plate.
  • To turn the unit off, press and hold the power button on the top plate.
If you accidently enter calibration mode, you can put it back to normal by connecting a USB charger.
2 other people completed this guide.
Kris
432 Reputation
3 Guides authored
1 Guide Comment
Great little guide thank you, I did this on the larger Timemore scale because the issue is in both products. I would say if you have a soldering iron its very easy not difficult
Zac Taylor - Reply Share
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 202
All Time: 1,965
