Timbuk2 - Quest Rolling Duffel Handle Replacement
  1. Timbuk2 - Quest Rolling Duffel Handle  Replacement, Gather materials: step 1, image 1 of 2 Timbuk2 - Quest Rolling Duffel Handle  Replacement, Gather materials: step 1, image 2 of 2
    • Before starting the repair, contact repairs@timbuk2.com and request a replacement handle.
    • Also obtain a Phillips screw driver and an Allen wrench (here an Allen wrench attachment bit was added to a drill)
  2. Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 2, image 1 of 2 Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 2, image 2 of 2
    • When you get your new handle, use the Phillips screw driver to remove the 2 screws at the bottom of the handle.
    • Once both screws are removed, pull off the black piece on the end.
    • Then set aside the major piece of the new roller to be used shortly and discard the black piece that detaches from the handle.
  3. Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 3, image 1 of 3 Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 3, image 2 of 3 Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 3, image 3 of 3
    • Open major part of the luggage and locate the zipper of the liner on the bottom of the bag.
    • Unzip the liner and locate the 2 screws.
    • Use the Philips screw driver to unscrew the 2 screws and set them aside.
  4. Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 4, image 1 of 3 Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 4, image 2 of 3 Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 4, image 3 of 3
    • Now locate the smaller section of the luggage on the top of the bag and unzip the pocket that exposes the handle grip.
    • Next, unzip the liner uncovering 2 bolts.
    • Use the Allen wrench to remove these 2 bolts and set them aside.
    • Then pull out the old handle from the luggage and discard.
  5. Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 5, image 1 of 3 Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 5, image 2 of 3 Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 5, image 3 of 3
    • Next, insert the new handle through the same opening the old one was removed.
    • *frustration reducing tip* Although the handle can reach all the way back to the base, push the new handle ALMOST to the end and line up the smaller hole with the bigger hole as shown in the picture.
    • THEN screw the 2 screws at the base and then screw back the bolts near the top of the handle.
  6. Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 6, image 1 of 2 Timbuk2 - Quest Rolling Duffel Handle  Replacement: step 6, image 2 of 2
    • Lastly, zip up all the zippers and you are
    • DONE!
    • Safe travels!
Timbuk2
583 Reputation
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 276
