Thrustmaster T3PM RJ12 main cable Replacement
  1. Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the pedal heads: step 1, image 1 of 2 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the pedal heads: step 1, image 2 of 2
    • Unscrew all 6 screws from the pedal heads
    • Note the positioning of the pedal heads or take this opportunity to try out new position
  2. Thrustmaster T3PM RJ12 main cable Replacement, Remove screws from the bottom: step 2, image 1 of 1
    • Use a Phillips driver to remove all screws at the bottom.
    • Keep track of each screw as to not loose it.
  3. Thrustmaster T3PM RJ12 main cable Replacement, Remove the top cover: step 3, image 1 of 1
    • Remove the top cover and put it aside
  4. Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: step 4, image 1 of 3 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: step 4, image 2 of 3 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: step 4, image 3 of 3
    • Use the Tweezers to carefully remove the wires from the sensors
  5. Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: step 5, image 1 of 3 Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: step 5, image 2 of 3 Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: step 5, image 3 of 3
    • Lift the tape and remove the cable
    • You can keep the original tape, add new tape or use some other method to stabilize the cable.
  6. Thrustmaster T3PM RJ12 main cable Replacement, Replace the cable: step 6, image 1 of 2 Thrustmaster T3PM RJ12 main cable Replacement, Replace the cable: step 6, image 2 of 2
    • Carefully connect the wires of a new cable with the sensors
To reassemble your pedal set, follow these instructions in reverse order.
Formica Fusca
2,595 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 89
All Time: 1,529
