Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement
  1. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, J1 Screws on Throttle: step 1, image 1 of 1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Panel: step 2, image 1 of 2 Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Panel: step 2, image 2 of 2
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Rudder: step 3, image 1 of 2 Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Rudder: step 3, image 2 of 2
    • Remove the four 13 mm J1 JIS head screws from the rudder assembly holder.
  4. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement: step 4, image 1 of 1
    • Gently remove the panel that is covering the rudder.
  5. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement: step 5, image 1 of 1
    • Proceed to remove the rudder from the throttle.
2 other people completed this guide.
Julissa Orozco
351 Reputation
2 Guides authored
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Members
13 Guides authored
One Comment
¿Haceraptencomr?
Alfredo Sanchez - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,845
