Introduction
Oh no! Did you tug too hard on the fan wire? No problem! Here is an easy fix to get your fan back in operation. You just need a few common tools. The fan used in the guide is the Thermaltake Riing 12 LED 120mm Radiator Cooling Fan with a 3-in connector; however, this guide is applicable on most fans.
Use a tweezer to push in on the crimp connector that is located in the fan header. Take out the connector
If difficulty occurs, try pushing on the connector through the notch of the fan header.
Almost done!
Voila! Your fan is good to go.
