Thermal Pad Replacement
    1. Thermal Pad Replacement, Thermal Paste: step 1, image 1 of 1
      • Before you start, make sure to ground yourself and your work surface properly to prevent damage from static electricity.
      Ask FixBot
    2. Thermal Pad Replacement, Heatsink: step 2, image 1 of 1
      • Unscrew the four heatsink screws from the back of the graphics card.
      • These are the ones nearest the PCIe connector, with the springs.
      Ask FixBot
    3. Thermal Pad Replacement: step 3, image 1 of 3 Thermal Pad Replacement: step 3, image 2 of 3 Thermal Pad Replacement: step 3, image 3 of 3
      • Gently lift the GPU and its backplate off the heatsink.
      • If the thermal paste on the GPU die is gluing it to the heatsink, warm it up a bit. Or carefully wiggle it side to side until it loosens.
      • Unplug the two cables holding the halves together.
      Ask FixBot
    4. Thermal Pad Replacement: step 4, image 1 of 1
      • Only the GPU die requires thermal paste; the other chips are covered by thermal pads under the black reinforcing frame.
      • Clean off the thermal paste and apply fresh paste.
      • Good quality thermal paste is recommended here - paste that keeps its consistency and won't dry out at high temperatures.
      • Skip this step and the next when replacing the thermal pads.
      Ask FixBot
    5. Thermal Pad Replacement, Reassembly: step 5, image 1 of 2 Thermal Pad Replacement, Reassembly: step 5, image 2 of 2
      • When reassembling, place the GPU on the heatsink, lining up the four holes for the screws.
      • Start each of the screws in their threaded holes before tightening any of them.
      • Tighten the screws a little at a time in a star pattern to keep even pressure on the GPU die.
      • Reconnect the two cables into the black sockets after the heatsink is secured.
      Ask FixBot
    1. Thermal Pad Replacement, Frame: step 6, image 1 of 1
      • Remove the 12 or so screws holding the frame and backplate together.
      • There are 4 black screws around the GPU die. The others are silver or black.
      Ask FixBot
    2. Thermal Pad Replacement, More screws: step 7, image 1 of 1
      • Remove the remaining two screws from the backplate.
      Ask FixBot
    3. Thermal Pad Replacement, Frame and thermal pads: step 8, image 1 of 1
      • If the frame is stuck to the circuit board, do not force it off. Warm the thermal pads, or drip a bit of isopropyl alcohol inder them. Using too much force can break trapped components off the board.
      • Remove the backplate, then carefully remove the black metal frame.
      • One big thermal pad and one narrow piece of foam go on top of the frame. The other four thermal pads go underneath.
      • Use thermal putty or thick thermal pads to cover the three sets of VRAM chips and the row of VRMs (under the big pad on the left).
      Ask FixBot
Sparky
1,731 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 43
Past 30 Days: 153
All Time: 211
