The Claw Bottom Cover Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. The Claw Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 1
      • Place The Claw in upright position with controls facing you.
      Ask FixBot
    2. The Claw Bottom Cover Replacement: step 2, image 1 of 1
      • Gently flip The Claw machine upside down with the controls facing you.
      Ask FixBot
    3. The Claw Bottom Cover Replacement: step 3, image 1 of 1
      • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
      • You will need a screwdriver with a long thin neck to fit in the screw holes.
      Ask FixBot
    4. The Claw Bottom Cover Replacement: step 4, image 1 of 2 The Claw Bottom Cover Replacement: step 4, image 2 of 2
      • Slide the bottom cover off to the side.
      • Do not completely remove bottom cover as it is still connected to wires.
      Ask FixBot
    5. The Claw Bottom Cover Replacement: step 5, image 1 of 1
      • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
      • You will need to cut the two green wires attached to the music player.
      • Then you will need to cut the white wire that leads to the battery compartment.
      • Finally you will need to cut the black wire leading to the battery compartment as well.
      • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: How To Solder and Desolder Connections.
      Ask FixBot
Alain Pierre
1,188 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 212
