Installing Texas Instruments TI-83 Plus Individual Keys
  1. Installing Texas Instruments TI-83 Plus Individual Keys, Backup Battery: step 1, image 1 of 2 Installing Texas Instruments TI-83 Plus Individual Keys, Backup Battery: step 1, image 2 of 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Installing Texas Instruments TI-83 Plus Individual Keys: step 2, image 1 of 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Installing Texas Instruments TI-83 Plus Individual Keys: step 3, image 1 of 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Installing Texas Instruments TI-83 Plus Individual Keys, Back Case: step 4, image 1 of 1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Installing Texas Instruments TI-83 Plus Individual Keys: step 5, image 1 of 2 Installing Texas Instruments TI-83 Plus Individual Keys: step 5, image 2 of 2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  6. Installing Texas Instruments TI-83 Plus Individual Keys, Motherboard & Screen: step 6, image 1 of 2 Installing Texas Instruments TI-83 Plus Individual Keys, Motherboard & Screen: step 6, image 2 of 2
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Installing Texas Instruments TI-83 Plus Individual Keys: step 7, image 1 of 2 Installing Texas Instruments TI-83 Plus Individual Keys: step 7, image 2 of 2
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
  8. Installing Texas Instruments TI-83 Plus Individual Keys, Keyboard Mat: step 8, image 1 of 2 Installing Texas Instruments TI-83 Plus Individual Keys, Keyboard Mat: step 8, image 2 of 2
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
  9. Installing Texas Instruments TI-83 Plus Individual Keys: step 9, image 1 of 1
    • Clean the contacts on the keyboard with a soft cloth.
  10. Installing Texas Instruments TI-83 Plus Individual Keys, Individual Keys: step 10, image 1 of 2 Installing Texas Instruments TI-83 Plus Individual Keys, Individual Keys: step 10, image 2 of 2
    • Use tweezers to remove one key at a time.
    • Be sure to keep them organized if you are taking out multiple keys.
Jared
151 Reputation
2 Guides authored
Cal Poly, Team 18-37, Regan Fall 2012 Member of Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 4,693
