Installing Texas Instruments TI-83 Plus Back Case
  1. Installing Texas Instruments TI-83 Plus Back Case, Backup Battery: step 1, image 1 of 2 Installing Texas Instruments TI-83 Plus Back Case, Backup Battery: step 1, image 2 of 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Installing Texas Instruments TI-83 Plus Back Case: step 2, image 1 of 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Installing Texas Instruments TI-83 Plus Back Case: step 3, image 1 of 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Installing Texas Instruments TI-83 Plus Back Case, Back Case: step 4, image 1 of 1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Installing Texas Instruments TI-83 Plus Back Case: step 5, image 1 of 2 Installing Texas Instruments TI-83 Plus Back Case: step 5, image 2 of 2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
Jared
151 Reputation
2 Guides authored
Cal Poly, Team 18-37, Regan Fall 2012 Member of Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 9,824
