Introduction
How to access and replace the motherboard and screen. Normally, there would be a guide for each component; however, the motherboard and screen are machine assembled as one unit.
Locate battery cover on the back of the case.
Slide battery cover to the right to reveal the batteries.
Slide the red lock up.
Slide the metal tab to the right of the bottom battery.
Remove the 3-Volt Lithium Coin Cell Battery.
Slide the red lock down.
Slide the metal tab to the right of the top battery.
Using a Torx, T-6 star-bit screwdriver unscrew four 7.38 mm screws from battery housing.
Unscrew four 7.15 mm screws from back casing.
Using the blue plastic opener tool along the seam of the case, pry off the back casing from the front casing.
Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
Using the blue plastic opening tool, pry the Motherboard up.
Using the blue plastic opening tool, pry up the screen from the screen mount.
