Introduction
If your screen is damaged or your mother board is not working, you will need to access and replace both.
Locate battery cover on the back of the case.
Slide battery cover to the right reveal the batteries.
Remove battery cover.
Slide the red lock down.
Slide the metal tab to the right of the top battery.
Remove the 3-Volt Lithium Coin Cell Battery.
Slide the red lock up.
Slide the metal tab to the right of the bottom battery.
Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
Unscrew four 7.15 mm screws from back casing.
Using the blue plastic opener tool along the seam of the case, pry off front casing.
Slide battery cover to the right to reveal the batteries.
Using a Torx, T-6 star-bit screwdriver unscrew four 7.38 mm screws from battery housing.
Using the blue plastic opener tool along the seam of the case, pry off the back casing from the front casing.
Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
Using the blue plastic opening tool, pry the Motherboard up.
Using the blue plastic opening tool, pry up the screen from the screen mount.
