De Longhi Heater temperature Sensor
  1. De Longhi Heater temperature Sensor, Temperature Sensor: step 1, image 1 of 1
    • Heater unit bricked with PF error (fault temperature sensor)
  2. De Longhi Heater temperature Sensor: step 2, image 1 of 1
    • Remove the four Phillips screws with a Phillips screwdriver
    • Remove the remaining 2 screws with a Torx screwdriver
    • Remove the cover
  3. De Longhi Heater temperature Sensor: step 3, image 1 of 1
    • Open the clamps by unhooking them with pliers or using a flathead screwdriver.
  4. De Longhi Heater temperature Sensor: step 4, image 1 of 1
    • Unscrew the Phillips screw to remove the temperature sensor.
  5. De Longhi Heater temperature Sensor: step 5, image 1 of 1
    • Unclip the temperature sensor connector from the motherboard.
  6. De Longhi Heater temperature Sensor: step 6, image 1 of 1
    • The temperature sensor had broken because it was corroded by moisture.
  7. De Longhi Heater temperature Sensor: step 7, image 1 of 2 De Longhi Heater temperature Sensor: step 7, image 2 of 2
    • With a soldering iron I proceeded to weld the broken part and to connect the 2 tracks by applying electric wire and some tin.
    • If the component can not be repaired, you can find the complete electronic board replacement on eBay
3 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,294 Reputation
39 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 77
All Time: 4,465
