Tent Pole Shock Cord Replacement
  1. Tent Pole Shock Cord Replacement, Tent Pole Shock Cord: step 1, image 1 of 1
    • Remove the old shock cord from the tent poles.
  2. Tent Pole Shock Cord Replacement: step 2, image 1 of 1
    • Measure and cut the string to the length of one tent pole piece.
    • Be sure to leave enough room on each end for knots.
  3. Tent Pole Shock Cord Replacement: step 3, image 1 of 1
    • Tie the string to the end of the shock cord.
  4. Tent Pole Shock Cord Replacement: step 4, image 1 of 2 Tent Pole Shock Cord Replacement: step 4, image 2 of 2
    • Use your hands or pliers to flatten out a bobby pin.
    • Any long, thin, metal object will work to help feed the string and cord through the poles.
  5. Tent Pole Shock Cord Replacement: step 5, image 1 of 1
    • Tie the string around the end of the bobby pin.
    • The string and bobby pin will be used to feed the shock cord through the pole.
  6. Tent Pole Shock Cord Replacement: step 6, image 1 of 3 Tent Pole Shock Cord Replacement: step 6, image 2 of 3 Tent Pole Shock Cord Replacement: step 6, image 3 of 3
    • Drop the bobby pin and string through the tent pole pieces one by one.
    • Once the bobby pin reaches the opposite end of each pole, slowly pull the string to feed the shock cord through.
  7. Tent Pole Shock Cord Replacement: step 7, image 1 of 2 Tent Pole Shock Cord Replacement: step 7, image 2 of 2
    • Once the last piece has been threaded, untie or cut the string from the shock cord.
    • Tie a large knot against the right end of the last piece.
    • The knot must be large enough to prevent the shock cord from slipping through the pole.
  8. Tent Pole Shock Cord Replacement: step 8, image 1 of 2 Tent Pole Shock Cord Replacement: step 8, image 2 of 2
    • Connect the tent poles.
  9. Tent Pole Shock Cord Replacement: step 9, image 1 of 1
    • Cut the shock cord from the left end of the first pole piece leaving room on the end for knots.
    • Leaving extra shock cord on the end will also allow you to adjust the tension in the shock cord later on.
  10. Tent Pole Shock Cord Replacement: step 10, image 1 of 2 Tent Pole Shock Cord Replacement: step 10, image 2 of 2
    • Tie a large knot around the tent pole end piece.
    • Fit the end piece into the left end of the first pole.
    • If your poles do not come with an end piece, simply tie a large knot in the shock cord. The knot must be large enough to prevent the shock cord from pulling through.
  11. Tent Pole Shock Cord Replacement: step 11, image 1 of 1
    • Disconnect the pole pieces.
    • Fold the pieces to test the shock cord tension.
    • If the shock cord is too tight, reconnect the poles and adjust the shock cord length between the left end of the first pole and the end piece.
3 other people completed this guide.
Kelsea Weber
19,877 Reputation
32 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,243 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 46
All Time: 20,402
