Tengda S5 Plus Speakers Replacement
  1. Tengda S5 Plus Speakers Replacement, Back Panel: step 1, image 1 of 1
    • Place the phone screen-side down.
  2. Tengda S5 Plus Speakers Replacement: step 2, image 1 of 2 Tengda S5 Plus Speakers Replacement: step 2, image 2 of 2
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Speakers Replacement, Speakers: step 3, image 1 of 1
    • Using either your thumb or an iFixit opening tool, remove the battery and set it aside.
  4. Tengda S5 Plus Speakers Replacement: step 4, image 1 of 1
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
  5. Tengda S5 Plus Speakers Replacement: step 5, image 1 of 2 Tengda S5 Plus Speakers Replacement: step 5, image 2 of 2
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Speakers Replacement: step 6, image 1 of 2 Tengda S5 Plus Speakers Replacement: step 6, image 2 of 2
    • Using an iFixit opening tool, remove the speakers.
    • Do not be afraid to use a little force. The speakers are glued onto the phone, not wired.
Andrew Lam
101 Reputation
1 Guide authored
Cal Poly, Team 14-9, Amido Spring 2015 Member of Cal Poly, Team 14-9, Amido Spring 2015
CPSU-AMIDO-S15S14G9
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 458
