Tengda S5 Plus Rear Camera Replacement
    1. Tengda S5 Plus Rear Camera Replacement, Back Panel: step 1, image 1 of 1
      • Place the phone screen-side down.
      Ask FixBot
    2. Tengda S5 Plus Rear Camera Replacement: step 2, image 1 of 2 Tengda S5 Plus Rear Camera Replacement: step 2, image 2 of 2
      • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
      • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
      Ask FixBot
    1. Tengda S5 Plus Rear Camera Replacement, Battery: step 3, image 1 of 1
      • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
      Ask FixBot
    1. Tengda S5 Plus Rear Camera Replacement, Rear Camera: step 4, image 1 of 1
      • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
      • Keep these screws in a safe place. They are very small and easy to lose.
      Ask FixBot
    2. Tengda S5 Plus Rear Camera Replacement: step 5, image 1 of 2 Tengda S5 Plus Rear Camera Replacement: step 5, image 2 of 2
      • Using the plastic opening tool, create space between the front screen and the metal casing.
      • Once the screen is separated from the back panel, pull the two pieces apart.
      Ask FixBot
    3. Tengda S5 Plus Rear Camera Replacement: step 6, image 1 of 1
      • Place the phone facing screen down.
      • Using the plastic prying tool, gently disconnect the black connector cable.
      • The connector cable should easy snap out with little force.
      Ask FixBot
    4. Tengda S5 Plus Rear Camera Replacement: step 7, image 1 of 1
      • Using the plastic prying tool, pry the camera from the tape holding it in place.
      • Be careful not to rip the tape.
      Ask FixBot
4 other people completed this guide.
Jholmesford
248 Reputation
1 Guide authored
Cal Poly, Team 14-9, Amido Spring 2015 Member of Cal Poly, Team 14-9, Amido Spring 2015
CPSU-AMIDO-S15S14G9
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 111
All Time: 731
