Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Temperature Controller with Pin Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
98
All Time:
532
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Guide for replacing the temperature controller with pin
    1. Temperature Controller with Pin Replacement, Temperature controller + pin + spring: step 1, image 1 of 1
      • You can simply pry the defective temperature controller out of its housing using a thin screwdriver. We recommend doing this carefully to avoid damaging the housing.
      Ask FixBot
    2. Temperature Controller with Pin Replacement: step 2, image 1 of 1
      • [To replace the pin + spring] After removing the temperature dial, you can now also remove and replace the pin (for the temperature dial's audio feedback) + spring.
      Ask FixBot
      • Now you can put the temperature control knob back onto the black knob. Make sure it is oriented correctly.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Author
with
binibini
397 Reputation
3 Guides authored
2 Guide Comments
Wie kann ich prüfen ob der Wassertank ein leck hat
und diesen ggf. ersetzen? Danke für Tipps
Katharina Siebler - Reply Share
alles prima, doch woher bekomme ich temperaturregler?
wenn der das problem ist, das bügeleisen wird nichtmehr heiß
und muss das nicht noch unter gewährleistung fallen? ich habe das gerät am 08.05.24 gekauft.
meldet euch bitte, auf welchem weg auch immer. email: uwe.leicht@t-online.de oder 01714343105
freundlichst
Uwe Leicht
Uwe Leicht - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 98
All Time: 532
