Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Technique: Removing plastic buttons and knobs without damage.
View statistics:
Past 24 Hours:
8
Past 7 Days:
35
Past 30 Days:
143
All Time:
531
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Community-Contributed Guide
    1. Technique: Removing plastic buttons and knobs without damage., Technique: Removing plastic buttons and knobs without damage.: step 1, image 1 of 2 Technique: Removing plastic buttons and knobs without damage., Technique: Removing plastic buttons and knobs without damage.: step 1, image 2 of 2
      • Normally, when we perform a teardown of a device where we need to remove knobs to continue with the disassembly phase (as is the case with this guitar pedal), we can try to pull them off by hand so as not to damage them or the casing.
      • If this is not possible because the knobs are in a recessed or deep position in the casing (as in the photo example), we can try to remove them by holding them with pliers, but there is a high risk of scratching or deforming them. Holding them with a piece of cloth is sometimes not the solution, as it slips and the pliers slide off.
      • A disassembly solution that works very well is to use a piece of rubber. For example, a piece of bicycle inner tube is very high-quality rubber that has many uses in DIY; if we wash it beforehand with water and dish soap, it has even greater grip once dried.
      Ask FixBot
    2. Technique: Removing plastic buttons and knobs without damage.: step 2, image 1 of 2 Technique: Removing plastic buttons and knobs without damage.: step 2, image 2 of 2
      • Here we see a bicycle inner tube, from which we can cut a piece.
      Ask FixBot
    3. Technique: Removing plastic buttons and knobs without damage.: step 3, image 1 of 3 Technique: Removing plastic buttons and knobs without damage.: step 3, image 2 of 3 Technique: Removing plastic buttons and knobs without damage.: step 3, image 3 of 3
      • Press down on the button and, using flat-nose pliers or universal pliers, carefully pull the button off.
      • I hope this DIY method is useful for future device teardowns.
      Ask FixBot
Finish Line
Author
with
Carlos López (España - Spain)
108,818 Reputation
402 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 35
Past 30 Days: 143
All Time: 531
