Shop the Holiday Gift Guide
Dell Inspiron 15-7548 Power Port Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
55
All Time:
893
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 6 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will walk you through how to remove the power port in your Dell Inspiron 15-7548.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Dell Inspiron 15-7548  Power Port Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 15-7548  Power Port Replacement, Back Panel: step 1, image 2 of 2
      • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
      • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
      • The four screws on the bottom are captive screws and cannot be removed.
      Ask FixBot
    2. Dell Inspiron 15-7548  Power Port Replacement: step 2, image 1 of 2 Dell Inspiron 15-7548  Power Port Replacement: step 2, image 2 of 2
      • Input the flat end of the spudger into the seam that is in between the back panel and the upper case, then slide it along the edge to release the plastic chips.
      • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
      Ask FixBot
    1. Dell Inspiron 15-7548  Power Port Replacement, Power Port: step 3, image 1 of 2 Dell Inspiron 15-7548  Power Port Replacement, Power Port: step 3, image 2 of 2
      • Grab the wires and lightly pull to remove the power port from the motherboard.
      Ask FixBot
Author
with
Christopher Fisher
409 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 55
All Time: 893
