Table Lamp Bulb and Wiring Replacement
    1. Table Lamp Bulb and Wiring Replacement, Bulb and Wiring: step 1, image 1 of 1
      • Switch off the lamp to ensure no electricity is flowing.
      • Unplug the lamp from the power outlet to prevent the risk of electric shock.
      • Wait a few minutes to allow any remaining electrical charge to dissipate.
      Ask FixBot
    2. Table Lamp Bulb and Wiring Replacement: step 2, image 1 of 1
      • Locate the screw at the base of the lamp that secures the light fixture to the structure.
      • Use the correct screwdriver/wrench (or if it the screw is loose enough, your hands) to carefully unscrew it while applying steady pressure.
      • Keep the screw in a secure place to avoid losing it during reassembly.
      Ask FixBot
    3. Table Lamp Bulb and Wiring Replacement: step 3, image 1 of 1
      • Hold the socket (the component that holds the bulb) firmly and check if it is attached with additional screws or clips.
      • Slowly pull the socket out of the fixture while being mindful of the connected wiring.
      Ask FixBot
    4. Table Lamp Bulb and Wiring Replacement: step 4, image 1 of 3 Table Lamp Bulb and Wiring Replacement: step 4, image 2 of 3 Table Lamp Bulb and Wiring Replacement: step 4, image 3 of 3
      • Grip the bulb securely and rotate it counterclockwise to loosen it from the socket.
      • Once removed, inspect the bulb for any visible damage and set it aside if it needs replacement.
      Ask FixBot
    5. Table Lamp Bulb and Wiring Replacement: step 5, image 1 of 3 Table Lamp Bulb and Wiring Replacement: step 5, image 2 of 3 Table Lamp Bulb and Wiring Replacement: step 5, image 3 of 3
      • Take off the white cover from bottom to top.
      Ask FixBot
    6. Table Lamp Bulb and Wiring Replacement: step 6, image 1 of 2 Table Lamp Bulb and Wiring Replacement: step 6, image 2 of 2
      • Cut both of the old wires with wire cutters.
      Ask FixBot
    7. Table Lamp Bulb and Wiring Replacement: step 7, image 1 of 2 Table Lamp Bulb and Wiring Replacement: step 7, image 2 of 2
      • Take out the new wire and make sure lamp wires correlate to its terminal.
      • Neutral is marked blue, hot is marked red.
      Ask FixBot
    8. Table Lamp Bulb and Wiring Replacement: step 8, image 1 of 1
      • Thread the wire through the small hole under the lamp.
      Ask FixBot
    9. Table Lamp Bulb and Wiring Replacement: step 9, image 1 of 2 Table Lamp Bulb and Wiring Replacement: step 9, image 2 of 2
      • Secure the wires to the screws using a Phillips screwdriver.
      • Tighten the screws so that the wires are secured under the screws.
      Ask FixBot
    10. Table Lamp Bulb and Wiring Replacement: step 10, image 1 of 1
      • Use a Phillips screwdriver to screw the wire between its correlating screw.
      • Blue is neutral, red is hot.
      Ask FixBot
    11. Table Lamp Bulb and Wiring Replacement: step 11, image 1 of 1
      • Plug the lamp in, and the bulb will light up.
      Ask FixBot
Finish Line
Jeffrey Cong
193 Reputation
1 Guide authored
UC Davis, Team 3-3, Andersen Winter 2025 Member of UC Davis, Team 3-3, Andersen Winter 2025
UCD-ANDERSEN-W25S3G3
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 100
All Time: 903
