TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement
  1. TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Remove bottom cover: step 1, image 1 of 1
    • Orient the laptop so that you can read the nameplate.
    • The front two screws (circled in red) are shorter than the remaining screws (circled in light green)
  2. TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Unplug the battery: step 2, image 1 of 3 TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Unplug the battery: step 2, image 2 of 3 TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Unplug the battery: step 2, image 3 of 3
    • To avoid damage, the battery should be disconnected
    • Carefully pull the plug out of the connector
  3. TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Replace SSD: step 3, image 1 of 3 TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Replace SSD: step 3, image 2 of 3 TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Replace SSD: step 3, image 3 of 3
    • The model has two M.2 NVMe slots
    • Red: PCIe 4.0 x4
    • Green: PCIe 3.0 x2
    • Remove the mounting screw
    • The SSD will then pop out of its anchorage
    • Then gently pull the SSD out of its slot
Follow these steps in reverse order to reassemble your device
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
LeCaNo
272 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 118
All Time: 1,724
