TUXEDO InfinityBook Pro 14 - Gen6 RAM Replacement
    1. TUXEDO InfinityBook Pro 14 - Gen6 RAM Replacement, Remove bottom case: step 1, image 1 of 1
      • Orient the laptop so that you can read the nameplate.
      • The front two screws (circled in red) are shorter than the remaining screws (circled in light green)
      Ask FixBot
    2. TUXEDO InfinityBook Pro 14 - Gen6 RAM Replacement, Disconnect the battery: step 2, image 1 of 3 TUXEDO InfinityBook Pro 14 - Gen6 RAM Replacement, Disconnect the battery: step 2, image 2 of 3 TUXEDO InfinityBook Pro 14 - Gen6 RAM Replacement, Disconnect the battery: step 2, image 3 of 3
      • To avoid damage, the battery should be unplugged
      • Carefully pull the plug out of the connector
      Ask FixBot
    3. TUXEDO InfinityBook Pro 14 - Gen6 RAM Replacement, Remove the memory: step 3, image 1 of 3 TUXEDO InfinityBook Pro 14 - Gen6 RAM Replacement, Remove the memory: step 3, image 2 of 3 TUXEDO InfinityBook Pro 14 - Gen6 RAM Replacement, Remove the memory: step 3, image 3 of 3
      • The main memory module is located under the two black foil covers above the battery
      • To remove a RAM strip, gently push apart the two metal clips on the left and right
      • The memory module then pops out of its socket
      • Pull the memory module out of the slot evenly and carefully.
      Ask FixBot
Follow these steps in reverse to reassemble your device
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
[deleted]
272 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 15
Past 30 Days: 37
All Time: 910
