Shop the Holiday Gift Guide
TSC Printer Latch Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
103
All Time:
751
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide is intended to help you replace the inner latch, which maintains spring tension in the bar that holds the print head down. If you have a 3D printer, you can get the model here.
Tools
    1. TSC Printer Latch Replacement, Getting access to the internals: step 1, image 1 of 2 TSC Printer Latch Replacement, Getting access to the internals: step 1, image 2 of 2
      • Begin by turning off your printer and unplugging your printer so that you have full access to it.
      • Open the printer cover.
      • Open the carriage by actuating the green handle.
      • Remove the two screws highlighted in red.
      • The blue plastic piece is what will need to be replaced to get spring tension to hold the print head down.
      Ask FixBot
    2. TSC Printer Latch Replacement, Remove the print roller: step 2, image 1 of 3 TSC Printer Latch Replacement, Remove the print roller: step 2, image 2 of 3 TSC Printer Latch Replacement, Remove the print roller: step 2, image 3 of 3
      • Remove the two screws denoted in red.
      • Remove the screw denoted in orange.
      • You will now be able to remove the bracket holding the print roller in by wiggling them both out.
      Ask FixBot
    3. TSC Printer Latch Replacement, Remove the assembly: step 3, image 1 of 1
      • Remove the three screws attaching holding the assembly to the printer.
      • The assembly has two cables running in to the printer and will no longer be supported by the screws.
      Ask FixBot
    4. TSC Printer Latch Replacement, Detach the cables: step 4, image 1 of 3 TSC Printer Latch Replacement, Detach the cables: step 4, image 2 of 3 TSC Printer Latch Replacement, Detach the cables: step 4, image 3 of 3
      • There are four screws holding the cover on: two denoted in red and two on the rear of the printer.
      • Once you have the cover off, disconnect the cable.
      • Now you can feed the cable through the hole.
      Ask FixBot
    5. TSC Printer Latch Replacement, Remove the sensor: step 5, image 1 of 1
      • Slide the sensor off of the assembly by pushing the sensor in the direction of the red arrow.
      Ask FixBot
    6. TSC Printer Latch Replacement, Replace the Latch: step 6, image 1 of 2 TSC Printer Latch Replacement, Replace the Latch: step 6, image 2 of 2
      • You now have access to the full assembly and can replace the broken piece.
      • There is a spring that adds tension to the print head retention bar. Ensure that it is properly installed into the replacement piece.
      Ask FixBot
Author
with
Emmett Normand
597 Reputation
3 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
1 Guide Comment
Your 3D print model is excellent – it really helps us a lot and saves both time and resources in our work. Thanks for sharing it!
The instructions for replacing the part are also very clear and well done.
I wanted to ask if you might also have a 3d model for the outer latch, the one you have to use to open the carriage ?
That would be incredibly helpful for us as well.
Pinkkittyx3 - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 103
All Time: 751
