TMY V08 Cooling Fan Replacement
    1. TMY V08 Cooling Fan Replacement, Top Panel: step 1, image 1 of 3 TMY V08 Cooling Fan Replacement, Top Panel: step 1, image 2 of 3 TMY V08 Cooling Fan Replacement, Top Panel: step 1, image 3 of 3
      • Turn the projector upside-down.
      • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
      • Turn the projector back over and lift the top casing panel off the projector.
      Ask FixBot
    2. TMY V08 Cooling Fan Replacement: step 2, image 1 of 3 TMY V08 Cooling Fan Replacement: step 2, image 2 of 3 TMY V08 Cooling Fan Replacement: step 2, image 3 of 3
      • Pinch and pull the bundled cable connector from the top panel.
      • Remove the top panel from the projector.
      Ask FixBot
    1. TMY V08 Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 3 TMY V08 Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 3 TMY V08 Cooling Fan Replacement, Cooling Fan: step 3, image 3 of 3
      • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
      • Pull back the motherboard to expose the connectors underneath.
      Ask FixBot
    2. TMY V08 Cooling Fan Replacement: step 4, image 1 of 2 TMY V08 Cooling Fan Replacement: step 4, image 2 of 2
      • Rotate the projector counterclockwise 90 degrees.
      • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
      Ask FixBot
    3. TMY V08 Cooling Fan Replacement: step 5, image 1 of 3 TMY V08 Cooling Fan Replacement: step 5, image 2 of 3 TMY V08 Cooling Fan Replacement: step 5, image 3 of 3
      • Rotate the projector counter clockwise with the front facing you.
      • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
      • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
      Ask FixBot
    4. TMY V08 Cooling Fan Replacement: step 6, image 1 of 3 TMY V08 Cooling Fan Replacement: step 6, image 2 of 3 TMY V08 Cooling Fan Replacement: step 6, image 3 of 3
      • Remove the five 7.3 mm screws from the black cover using a Phillips #1 screwdriver.
      • Take off the right black cover, exposing the fan.
      Ask FixBot
    5. TMY V08 Cooling Fan Replacement: step 7, image 1 of 1
      • Firmly grasp and lift up the fan to remove it.
      Ask FixBot
2 Guide Comments
Question, great guide by the way, do you know the sizes of the fans inside this unit?
JTone - Reply Share
the reason i ask, i am pretty new to electronics repair but i wanted to see if there was a way i could get fan that run quieter in this unit.
JTone - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 41
All Time: 661
