TMY V08 Button Circuit Board Replacement
  1. TMY V08 Button Circuit Board Replacement, Top Panel: step 1, image 1 of 3 TMY V08 Button Circuit Board Replacement, Top Panel: step 1, image 2 of 3 TMY V08 Button Circuit Board Replacement, Top Panel: step 1, image 3 of 3
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
  2. TMY V08 Button Circuit Board Replacement: step 2, image 1 of 3 TMY V08 Button Circuit Board Replacement: step 2, image 2 of 3 TMY V08 Button Circuit Board Replacement: step 2, image 3 of 3
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
  3. TMY V08 Button Circuit Board Replacement, Button Circuit Board: step 3, image 1 of 3 TMY V08 Button Circuit Board Replacement, Button Circuit Board: step 3, image 2 of 3 TMY V08 Button Circuit Board Replacement, Button Circuit Board: step 3, image 3 of 3
    • Remove the four 4.8 mm screws from the button circuit board beneath the top cover using a Phillips #1 screwdriver.
    • Remove the button circuit board.
Joanna Jimenez
73 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 189
