TLC 505 Screen Replacement
    1. TLC 505 Screen Replacement, Screen: step 1, image 1 of 3 TLC 505 Screen Replacement, Screen: step 1, image 2 of 3 TLC 505 Screen Replacement, Screen: step 1, image 3 of 3
      • heat up on a heat pad. use some 99% IPA around the edge and a small plastic splugger.
      Ask FixBot
    2. TLC 505 Screen Replacement: step 2, image 1 of 3 TLC 505 Screen Replacement: step 2, image 2 of 3 TLC 505 Screen Replacement: step 2, image 3 of 3
      • remove all the philips screw and sim try.
      • with the plasic splugger insert by the sim tray cover and pry off the rear frame
      Ask FixBot
    3. TLC 505 Screen Replacement: step 3, image 1 of 2 TLC 505 Screen Replacement: step 3, image 2 of 2
      • disconnect the battery cable (Black Connector) and screen cable Bottom Left Cable (Top Board) & Top Right cable ( Bottom Board)
      Ask FixBot
    4. TLC 505 Screen Replacement: step 4, image 1 of 1
      • Use 99% IPA & Pry Tool to remove Battery
      Ask FixBot
    5. TLC 505 Screen Replacement: step 5, image 1 of 3 TLC 505 Screen Replacement: step 5, image 2 of 3 TLC 505 Screen Replacement: step 5, image 3 of 3
      • heat up the screen and push from battery side
      • carfuly pry round the screen to lift use 99%IPA if need
      Ask FixBot
    6. TLC 505 Screen Replacement: step 6, image 1 of 2 TLC 505 Screen Replacement: step 6, image 2 of 2
      • test fit new screen
      • you can use B700 to reglue the screen in (BE CARFUL AROUND TOP CAM) or can tape and fit
      Ask FixBot
Madskills
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 54
All Time: 215
