TI-Nspire CAS Teardown
  1. TI-Nspire CAS Teardown, Take out the AAA Batteries: step 1, image 1 of 3 TI-Nspire CAS Teardown, Take out the AAA Batteries: step 1, image 2 of 3 TI-Nspire CAS Teardown, Take out the AAA Batteries: step 1, image 3 of 3
    • Turn your calculator over and flip the spring loaded switch to the right. The keypad on the front should pop down. Lift the keypad off and take out the 4 AAA batteries.
  2. TI-Nspire CAS Teardown, Take of the Back Cover: step 2, image 1 of 3 TI-Nspire CAS Teardown, Take of the Back Cover: step 2, image 2 of 3 TI-Nspire CAS Teardown, Take of the Back Cover: step 2, image 3 of 3
    • Unscrew the 2 screws on the top of the back of the calculator. Use a Phillips PH00 screwdriver. If your calculator has a lithium ion battery, unplug the cable and gently lift the battery out from the bottom left.
  3. TI-Nspire CAS Teardown, Take out the Back Screws: step 3, image 1 of 3 TI-Nspire CAS Teardown, Take out the Back Screws: step 3, image 2 of 3 TI-Nspire CAS Teardown, Take out the Back Screws: step 3, image 3 of 3
    • Use your Torx T6 screwdriver to take out the 6 identical screws. After you take out the screws gently pop off the back plate.
  4. TI-Nspire CAS Teardown, Taking the Screen and Mother Board Out: step 4, image 1 of 3 TI-Nspire CAS Teardown, Taking the Screen and Mother Board Out: step 4, image 2 of 3 TI-Nspire CAS Teardown, Taking the Screen and Mother Board Out: step 4, image 3 of 3
    • Once you have taken the back plate completely off, unscrew 6 phillips head screws. Remember, these screws are different so keep them separate. After taking the screws out, carefully lift the bottom of the screen up and then the screen and board out.
  5. TI-Nspire CAS Teardown, Brackets: step 5, image 1 of 3 TI-Nspire CAS Teardown, Brackets: step 5, image 2 of 3 TI-Nspire CAS Teardown, Brackets: step 5, image 3 of 3
    • If you need to, you can pull the battery terminals up and out, but if you don't need to you shouldn't. Next, unscrew 2 screws and take out the 2 brackets.
  6. TI-Nspire CAS Teardown, Reassembly: step 6, image 1 of 1
    • Fallow this guide in reverse to reassemble your calculator.
Finish Line
Philip Sophocleous
290 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 35
All Time: 2,365
