Installing Batteries into a TI-Nspire Calculator
  1. Installing Batteries into a TI-Nspire Calculator, Battery: step 1, image 1 of 1
    • Face the side of the calculator with the "Texas Instruments" logo towards you, with the logo upright.
    • Slide the front cover down to remove it.
  2. Installing Batteries into a TI-Nspire Calculator: step 2, image 1 of 2 Installing Batteries into a TI-Nspire Calculator: step 2, image 2 of 2
    • The calculator should be facing front with the screen on the top and the keypad on the bottom.
    • Hold the long side of the calculator on the right or left and turn it 180 degrees so that the back of the calculator faces you.
    • Make sure that the current side facing you is the back by checking that the side has a "reset" button.
  3. Installing Batteries into a TI-Nspire Calculator: step 3, image 1 of 1
    • Locate the area with a switch on the bottom half of the calculator. Make the sure the switch is on the left side of the switch area, which indicates that it is locked.
    • Slide the switch until it moves from the left side of the button area all the way to the right side.
    • Make sure to hear a click once you move the switch all the way to the right, which indicates the keypad is now removable.
  4. Installing Batteries into a TI-Nspire Calculator: step 4, image 1 of 1
    • Turn the calculator back to the front as you would normally use it.
  5. Installing Batteries into a TI-Nspire Calculator: step 5, image 1 of 2 Installing Batteries into a TI-Nspire Calculator: step 5, image 2 of 2
    • Put your hand on the keypad, slide the keypad down about a half inch, and pull up to remove the keypad.
  6. Installing Batteries into a TI-Nspire Calculator: step 6, image 1 of 1
    • The batteries should be on the right and left side in the keypad area, with two on each side.
    • Place the tip of your finger in between the batteries, and remove the batteries. Repeat this for the other side as well.
  7. Installing Batteries into a TI-Nspire Calculator: step 7, image 1 of 1
    • When reassembling your device, use four new batteries.
Clincy Cheung
223 Reputation
1 Guide authored
Cal Poly, Team 7-52, Forte Fall 2012 Member of Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 17,103
