TI-84 Plus Silver Edition Backup Battery Replacement
  1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: step 1, image 1 of 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: step 1, image 2 of 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: step 1, image 3 of 3
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Backup Battery Replacement: step 2, image 1 of 1
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
  3. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: step 3, image 1 of 1
    • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
  4. TI-84 Plus Silver Edition Backup Battery Replacement: step 4, image 1 of 1
    • Grab the plate and lift gently upward, to remove the backup battery cover.
  5. TI-84 Plus Silver Edition Backup Battery Replacement: step 5, image 1 of 2 TI-84 Plus Silver Edition Backup Battery Replacement: step 5, image 2 of 2
    • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
    • Push gently downward until the backup battery pops out.
Agustin
1,028 Reputation
2 Guides authored
Cal Poly, Team 11-34, Amido Fall 2013 Member of Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Members
6 Guides authored
Past 24 Hours: 9
Past 7 Days: 60
Past 30 Days: 279
All Time: 65,850
