Swiffer WetJet Motor Replacement
  1. Swiffer WetJet Motor Replacement, Swiffer WetJet Motor Replacement: step 1, image 1 of 3 Swiffer WetJet Motor Replacement, Swiffer WetJet Motor Replacement: step 1, image 2 of 3 Swiffer WetJet Motor Replacement, Swiffer WetJet Motor Replacement: step 1, image 3 of 3
    • Remove the cleaning solution, batteries and the battery container.
    • Use a Phillips #1 screwdriver to remove the screw (1.4x6.0mm) at the bottom of the WetJet.
    • Remove two more screws (1.4x5.0mm) in the interior where the cleaning solution is placed.
    Ask FixBot
  2. Swiffer WetJet Motor Replacement: step 2, image 1 of 2 Swiffer WetJet Motor Replacement: step 2, image 2 of 2
    • Use two hands to remove the cover of the Swiffer by lifting the bottom part with one hand while with the other hand pull the cover from the cleaning solution release button.
    Ask FixBot
  3. Swiffer WetJet Motor Replacement: step 3, image 1 of 1
    • Dissasemble the head of the Swiffer WetJet to leave the engine alone and be able to work with it freely.
    Ask FixBot
  4. Swiffer WetJet Motor Replacement: step 4, image 1 of 1
    • Remove the internal screw (1.4x5.0mm) that holds the release cleaning solution button.
    Ask FixBot
  5. Swiffer WetJet Motor Replacement: step 5, image 1 of 1
    • With a flathead screwdriver (1/4), deatach the button to release the cleaning solution by lifting it with your hands.
    Ask FixBot
  6. Swiffer WetJet Motor Replacement: step 6, image 1 of 2 Swiffer WetJet Motor Replacement: step 6, image 2 of 2
    • Remove the spring of the release button.
    Ask FixBot
  7. Swiffer WetJet Motor Replacement: step 7, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the three screws (1.4x6.0mm) that hold the motor compartment.
    Ask FixBot
  8. Swiffer WetJet Motor Replacement: step 8, image 1 of 2 Swiffer WetJet Motor Replacement: step 8, image 2 of 2
    • Once removed detach the motor.
    Ask FixBot
  9. Swiffer WetJet Motor Replacement: step 9, image 1 of 3 Swiffer WetJet Motor Replacement: step 9, image 2 of 3 Swiffer WetJet Motor Replacement: step 9, image 3 of 3
    • Using the same Phillips screwdriver (#0) remove another three screws (1.2x10mm) to release the motor.
    • Detach the cleaning solution tube.
    • Remove the two power cables and the motor will be released.
    Ask FixBot
3 other people completed this guide.
4 Guide Comments
Looks like a good guide. My version of the wetjet is slightly different, the motor has a pc attached. But where do you get the replacement motor?
Enderke - Reply Share
Thanks for the guide! I was able to replace the motor in our Swiffer with a spare mini "370" pump motor that happened to have an identical motor section once the pump was taken apart. Refer to my Imgur gallery for more info on disassembly.
The motor I used was "DC 3V-5V 3.7V Micro 370 Motor Mini Air Pump Vacuum Pump Self-Priming Pump" something like this motor.
Imgur Gallery: imgur.com/a/YQ5SvgG
Justin W - Reply Share
Thank you! You're resources were invaluable. I've been trying to fix things since I got pregnant. A weird existential nesting. I finally have a success! Thanks to you. I am not handy but %#*!^@ I fixed our 5 year old swiffer wet jet.
Jessica Donahue - Reply Share
I need a link to a replacement motor.
Dummy Fixer - Reply Share
Past 24 Hours: 6
Past 7 Days: 52
Past 30 Days: 236
All Time: 5,837
