Community-Contributed Guide
Tools
Swatch band (blue) is very likely to fail (due to stress concentration and fatigue) and is different from a standard one (brown).
Using Dremel carefully cut two slots to acomodate the band to the swatch body.
Here you go! Your band is adapted and assembled to your swatch.
Advise: Buy a good band with good thickness at the fulcrum, otherwise it may be weakened excessively by the cutting.
Good luck with battling the programmed obsolescence!
2 other people completed this guide.
1 Guide Comment
I have a swatch watch band that has print one each side of the watch that are broken but not broken all the way through is there a glue or epoxy I can use to preserve the original bands with the print on the front?
