Swagtron T3 Wheel Replacement
  1. Swagtron T3 Wheel Replacement, Cover: step 1, image 1 of 2 Swagtron T3 Wheel Replacement, Cover: step 1, image 2 of 2
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
  2. Swagtron T3 Wheel Replacement: step 2, image 1 of 3 Swagtron T3 Wheel Replacement: step 2, image 2 of 3 Swagtron T3 Wheel Replacement: step 2, image 3 of 3
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
  3. Swagtron T3 Wheel Replacement, Wheel: step 3, image 1 of 1
    • Unscrew the six 11.2 mm Phillips machine screws from the inside of the wheel.
    • You many need to spray a thin lubricant, such as PB Blaster, directly onto each of the six screw points to loosen them.
  4. Swagtron T3 Wheel Replacement: step 4, image 1 of 2 Swagtron T3 Wheel Replacement: step 4, image 2 of 2
    • Pull the wheel off of its base.
    • The wheel has a strong magnetic connection to the base, so separating the them will require a lot of force.
Klara Perkins
412 Reputation
2 Guides authored
Cal Poly, Team S13-G3, Forte Spring 2017 Member of Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 Members
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 4,141
