Cabin air filter replacement for a SEAT Cordoba II (2002-2009)
  1. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: step 1, image 1 of 2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: step 1, image 2 of 2
    • The cabin air filter is located in the passenger side footwell
  2. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: step 2, image 1 of 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: step 2, image 2 of 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: step 2, image 3 of 3
    • Remove the cover by loosening the four screws that hold it in place, keeping track of where they go to replace them in the some holes.
    • Once that the screws are removed, the cover will come down.
  3. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: step 3, image 1 of 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: step 3, image 2 of 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: step 3, image 3 of 3
    • Now with more room to remove it, slide the two plastic tabs together.
    • When the two plastic tabs are in the middle pull the filter cover down.
  4. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: step 4, image 1 of 2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: step 4, image 2 of 2
    • Remove the filter.
    • Once you remove the filter make sure to notice the direction of the air-flow arrows so that you install the new one in the same direction.
  5. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Re-assembly: step 5, image 1 of 1
    • To install the new filter follow the previous steps in reverse. If the filter and the plastic cover don't install fully, it is possible that it is installed backwards.
    • When re-installing the cover re-insert the tab and push upwards. Then reinstall the screws.
Finish Line
5 other people completed this guide.
Special thanks to these translators:
es en
100%
WhoDat? is helping us fix the world! Want to contribute?
Start translating ›
Jonatan M
530 Reputation
2 Guides authored
One Comment
me agremio para conocer formas de reparar yo mismo y economisar el presupuesto mensual
oscar ibarra - Reply
Past 24 Hours: 6
Past 7 Days: 33
Past 30 Days: 219
All Time: 7,004
